P: PCB5.0E Willem EPROM Programmer
Doomm je teď offline  Doomm
PříspěvekZaslal: 10.11.2014 , 20:28   Citovat
Prodám PCB5.0E Willem EPROM Programmer viz foto
v balení je napájecí USB a datový LPT kabel
podporuje:
citace:
EPROM 27C64 , 27C128 , 27C256 , 27C512 , 27C010 , 27C020 , 27C040 , 27C1001
M27C1001 , M27C2001 , M27C4001 , 27C080 (A19) , M27C801 , M87C257
2716 (Vpp25V) , 2732 , (adapter DIP24) , 2764 , 27128 , 27256 , 27512 , 27010,
Vpp12.5V (21Vpp Modify Circuit)
EEPROM 28C65 , 28C64 , 28C128 , 28C256 , 28C512 , 28C010 , 28C020 , 28C040
M28C16A/17A (DIP28)
(Adapter or Jumper)28C16,XLS2816 (DIP24)
FLASH Memory 28F64 , 28F128 , 28F256 , 28F512 , 28F010 , 28F020 , SST39VF1601 , SST49LF002B , SST49LF003B , SST49LF004B , SST39LF040B
SST39LF/VF020 , MX26C1000 , MX26C2000 , MX28F1000 , MX28F2000 , A49LF004TL-33F , A49LF004TX , A49LF040A , A49LF040N , 49LF040TL , A49LF040TL
Am28F256A , Am28F512A , Am28F010A , Am28F020A (New command erase/prog.) , A49LF004 , A49LF004TL , A49LF004TL
A49LF040TL-33C , A49LF040TX
-- intel --- i28F001BX , 28F004 , 28F008 , 28F016
-- Winbond --- 39v040AP , 39v080AP , W39V040FA , W39V040FAP , W39V040BP , W39V04OBPZ , W49V040FBPZ , W39V040FCP , W39V040FCPZ
W39V080AP , W39V080APZ , W39V080FAP , W39V080FAPZ
SPD IC: SD Memory: SPD24C02 , SPD24C04 , SPD24C08 , SPD24C16 , SPD24C32(32)
DDR Memory: SPD 24C02 , 24C04 , 24C08 , 24C16 , 24C32(32) , 93C06(8 bit) , 93C46(8 bit) , 93C56(8 bit) , 93C57t(8 bit) , 93C66(8 bit) , 93C76t(8 bit)
PM49FL002T , PM49FL004T , PM49FL008T , PM49F002T , PM49F020 , PM49F008T , PM49F020A , PM49F004T , PM49F040 , PM49FLxx , EON29Fxx
FLASH Memory 29F64 , 29F128 , 29F256 , 29F512 , 29F010 , 29F020 , 29F040 , 29F080 , 29F001 , 29F002 , 29F004 , 29F008 , 29F016 , 29F032 , V29C51002T , 29LV040
Serial (I2C) EEPROM
24Cxx
24C02 , 24C04 , 24C08 , 24C16 , 85C72 , 85C82 , 85C92
--- page write ----
24C32 , 24C64 , 24C128 , 24C256 , 24C512
Microwire EEPROM
<------ Data 8bit -----> (pin 6 ->ORG. [Schematic connect to GND])
93C06 , 93C46 , 93LC46 , 93C56 , 993C57, 93C66 , 93C76 , 93C86 (8bit)
AT59C11 , AT59C22 , 9AT59C13, CAT35C102 , CAT35C104 , CAT35C108 (pullup pin7)
<------Data 16bit ------> (pin 6 ->NC [No Connect])
93C06A , 93C46X , 93C56 , 93C66 , 93C76 , 93C86 (NS)
Microchip PIC 16C84 , 16F84 , 16F84A , 16F627/16F628 , 12C508/A , 12C509/A , 12CE518 , 12CE519 , 16C505
16C620 , 16C621 , 16C622 , 16CE623 , 16CE624 , 16CE625 , 16C710/711
---ICSP connector----
16F870 , 16F871 , 16F872 , 16F873 , 16F874 , 16F876 , 16F877 PIC16F873A , PIC16F874A , PIC16F876A , PIC16F877A
-Add PIC microchip 14bit
PIC12F629 , PIC12F675 , PIC16F630 , PIC16F676 , PIC12F635 , PIC12F683 , PIC16F636 , PIC16F684 , PIC16F688
PIC16F72 , PIC16F73 , PIC16F74 , PIC16F76 , PIC16F77 , PIC16F737 , PIC16F747 , PIC16F767 , PIC16F777 , PIC16F87/88 , PIC12F675x , PIC16F785/PS200 , PIC16F716
-Add microchip 14bit,12bit OTP
PIC12C671 , PIC12C672 , PIC12CE673 , PIC12CE674 , PIC16C61 , PIC16C71 , PIC16C62/64 , PIC16C65 , PIC16C73
PIC16C62A , PIC16C62B , PIC16C62C , PIC16C63 , PIC16C63A , PIC16C64A , PIC16C65A , PIC16C65B , PIC16C66 , PIC16C67
PIC16C72 , PIC16C72A , PIC16C73A , PIC16C74A , PIC16C74B , PIC16C76 , PIC16C77 , PIC16C620 , PIC16C620A , PIC16C621 , PIC16C621A , PIC16C622 , PIC16C622A
PIC16CE623 , PIC16CE624 , PIC16CE625 , PIC16C710 , PIC16C711 , PIC16C712 , PIC16C716 , PIC16C773 , PIC16C774 , PIC16C745 , PIC16C765 , PIC16C923 , PIC16C924
PIC16C925 , PIC16C926 , PIC16C554 , PIC16C556 , PIC16C557 , PIC16C558 , PIC16C432 , PIC16C433 , PIC16C717 , PIC16C770 , PIC16C771 , PIC16C781 , PIC16C782
-Additional PIC microchip 14bit
PIC12F629 , PIC12F675 , PIC16F630 , PIC16F676 , PIC12F635 , PIC12F683 , PIC16F636 , PIC16F684 , PIC16F688 , PIC16F72 , PIC16F73 , PIC16F74
PIC16F76 , PIC16F77 , PIC16F737 , PIC16F747 , PIC16F767 , PIC16F777 , PIC16F87 , PIC16F88 , rfPIC12F675x , PIC16F785 , PS200 , PIC16F716
-Additional microchip 14bit OTP
PIC12C671 , PIC12C672 , PIC12CE673 , PIC12CE674 , PIC16C61 , PIC16C71 , PIC16C62 , PIC16C64 , PIC16C65 , PIC16C73
PIC16C62A , PIC16C62B , PIC16C62C , PIC16C63 , PIC16C63A , PIC16C64A , PIC16C65A , PIC16C65B , PIC16C66 , PIC16C67 , PIC16C72 , PIC16C72A , PIC16C73A , PIC16C74A
PIC16C74B , PIC16C76 , PIC16C77 , PIC16C620 , PIC16C620A , PIC16C621 , PIC16C621A , PIC16C622 , PIC16C622A , PIC16CE623 , PIC16CE624 , PIC16CE625 , PIC16C710 , PIC16C711
PIC16C712 , PIC16C716 , PIC16C773 , PIC16C774 , PIC16C745 , PIC16C765 , PIC16C923 , PIC16C924 , PIC16C925 , PIC16C926 , PIC16C554 , PIC16C556 , PIC16C557 , PIC16C558
-Additional PIC microchip 12bit (FLASH memory)
PIC12F508 , PIC12F509 , PIC10F200 , PIC10F202 , PIC10F204 , PIC10F206 , PIC16F505 , PIC16F54 , PIC16F57
-Add PIC18Fxxx
PIC18F242 , 18F248 , 18F252 , 18F258 , 18F442 , 18F448 , 16F452 , 16F458
PIC18F1220 , 18F2220 , 18F4220 , 18F1320 , 18F2320 , 18F4320 , PIC18F6520 , 18F6620 , 18F6720 , 18F8520 , 18F8620 , 18F8720
PIC18F2331 , 18F2431 , 18F4331 , 18F4431 , PIC18F6525 , 18F6621 , 18F8525 , 18F8621 , PIC18F6585 , 18F6680 , 18F8585 , 18F8680 , PIC18F2439 , 18F2539 , 18F4439 , 18F4539
PIC18F6410 , 18F8410 , 18F6490 , 18F8490
-Additional PIC18Fxxx
PIC18F2410 , PIC18F2420 , PIC18F2455
PIC18F2510 , PIC18F2515 , PIC18F2520 , PIC18F2525 , PIC18F2550 , PIC18F2585 , PIC18F2610 , PIC18F2620 , PIC18F2680 , PIC18F4410, PIC18F4420 , PIC18F4455
PIC18F4510 , PIC18F4515 , PIC18F4520 , PIC18F4525 , PIC18F4550 , PIC18F4585 , PIC18F4610 , PIC18F4620 , PIC18F4680
-Additional Find and edit value OSCCAL (PIC12F629 , PIC12F675 , PIC16F630 , PIC16F676)
-Additional Edit config at address 0x2008,0x2009 (PIC12F635 , PIC12F683 , PIC16F636 , PIC16F684 , PIC16F688 , PIC16F785)
Fixed Programming PIC all
PIC12F675 , PIC16F676 , PIC16F684 ,PIC16F767 , PIC16F74 , PIC16F872 , PIC16F876 , PIC16F877 , PIC16F876A , PIC16F873A, PIC16F819
PIC16F84 , PIC16F84A , PIC16F628, PIC16F628A,
eprom PIC12C509JW , PIC16C505JW , PIC16C711JW , PIC16CE625JW , PIC18F458 , PIC18F4320 , PIC18LF258 , PIC18F4539 , PIC18F4431
Atmel Flash Memory AT29C256 , AT29C512 , AT29C010A , AT29C020 , AT29C040 , AT29C040A
W29EE512 , W29EE011 , W29EE012 , W29C020(128) , W29C040 , PH29EE010(W29EE011)
ASD AE29F1008 (AT29C010), AE29F2008 (AT29C020)
Ver 0.992 up(DOS). Can run under win9x
(disable prog. CPUIdle or CPUCool) AT49BV512
Atmel Flash Memory
AT49Fxxx (Subset 29Fxxx) Command seq. 5555/AA, 2AAA/55, 5555/A0
AT49F512 , AT49F010 , AT49F020 , AT49F040 , SST39SF010 , SST3S9F020 , SST39SF040 , AT49F001 , AT49F002 , AT49F008A
Command seq. 555/AA, 2AA/55, 555/A0
Am29F512 , Am29F010 , Am29F020 , Am29F040 , HY29F080 , 29F002 , 29F002T , Pm29F002T
Serial Peripheral Interface (SPI)
EEPROM Mode0 (0,0)
AT25xxx, W95xxx
[Atmel] AT25010 , 020 , 040 (A8-A0)
AT25080 , 160 , 320 , 640 , 128 , 256 (A15-A0)
[ST] W95010....256, Microchip 25x010 - 25x640
--- Byte programming
25010 , 25020 , 25040
--- Page programming
25C080 , 25C160 , 25C320 , 25C640 , 25C128 , 25C256 , 25C512
AT25HP256 , AT25HP512 , M25P10 , M25P20 , M25P40
AT25HP1024 (24bit address)
-- CAT64LCxxx (16bit DATA IN/OUT) use Socket 93Cxxx
CAT64LC010, CAT64LC020, CAT64LC040
Atmel EEPROM
AT28C256 , AT28C010 , AT28C040
Nonvaltile SRAM (DS12xx) DS1220 , DS1225Y , DS1230Y/AB , DS1245Y/AB , DS1249Y/AB
static RAM (Test RAM)
6116 , 6264 , 62256 , 62512 , 628128
EPROM winbond,SST
Electrical Erase Chip
W27E512 , W27E010 , W27C010 , W27C020 , W27C040
SST27SF256 , SST27SF512 , SST27SF010 , SST27SF020
MX26C4000
Vcc = 3.3-3.6V SST37VF512 , SST37VF010 , SST37VF020 , SST37VF040
Flash Memory SST , Sanyo SST28SF040A , LE28F4001
SPI FLASH CHIPS ADDITIONAL SUPPORTED DEVICES
AMIC A25L05P-B, A25L10P-B, A25L20P-B, A25L05P-T, A25L10P-T, A25L20P-T, A25L512
A25L010, A25L020, A25L040, A25L080, A25L016
ATMEL AT25F512, AT25F1024, AT25F2048, AT25FS010, AT25FS020
AT25F010, AT25F040
AT25DF021, AT25DF041, AT25DF161, AT25DF321, AT25DF641
AT25D081A
EON EN25B05, EN25B10, EN25B20, EN25B40, EN25B80, EN25B16, EN25B32, EN25B64, EN25P05, EN25P10, EN25P20, EN25P40, EN25P80, EN25P16 ,EN25P32, EN25P64, EN25D80, EN25D16
EN25F20, EN25F40, EN25F80, EN25F16, EN25T80
MXIC MX25L512, MX25L1005, MX25L2005, MX25L4005, MX25L8005, MX25L1605, MX25L3205, MX25L6405
Numonyx (ST)
M25P05, M25P10, M25P20, M25P40, M25P80, M25P16, M25P32, M25P64, M25PE10, M25PE20, M25PE40, M25PE80
M25PX80, M25PX16, M25PX32, M25PX64
P-FLASH Pm25LV512, Pm25LV010, Pm25LV020, Pm25LV040, Pm25LV080, Pm25LV016
SPANSION S25FL004A/040A, S25FL008A, S25FL040A-T, S25FL040A-B, S25FL016A, S25FL032A, S25FL064A, S25L128
WINBOND W25P10, W25P20, W25P40, W25P80, W25P16, W25P32
W25X01, W25X02, W25X04, W25X08
W25X16, W25X32, W25X64, W25B40A
GigaDevice GD25F40, GD25F80, GD25D40, GD25D80, GD25T80
ESMT F25L004A, F25L008A, F25L016A, F25L032PA, F25L04UA,
F25S04PA, F25S08PA, F25S16PA, F25L32QA
MicroChip 25LC(AA)1024
Cena: 1500 + posta
kee_pcb50e.jpg, 323.49 kB
Příspěvky: 2410 1998 Civic
PříspěvekZaslal: 19.11.2014 , 18:07   Citovat
up
JDM Factory je teď offline  JDM Factory
PříspěvekZaslal: 19.11.2014 , 19:42   Citovat
Ku comu sa to da vyuzit?
PříspěvekZaslal: 21.11.2014 , 22:38   Citovat
JDM Factory napsal:
na programovani pameti (chipu) do honda jednotek
[ Čas: 0.0727s ][ Dotazy: 43 (0.0061s) ][ GZIP on - Debug on ]
