CRX D16Z6 N/A 202HP/185Nm
Filipo je teď offline  Filipo
PříspěvekZaslal: 29.12.2014 , 15:35  Naposledy upravil Filipo dne 2.2.2015 , 12:23, celkově upraveno 1 krát. Citovat
Zdravím kamarád z Polska prodává svoje crx a požádal mě jestli bych mu nedal inzerát i semka.
Inzerát je v angličtině, tu většina z nás přelouská lépe než polštinu a kdyžtak poradí strejda google..
Kontaktujte přímo ho, dole je uvedený telefon a mail..
Komunikuje polsky nebo anglicky
Popis auta:
For sale Honda CRX D16Z6 ED9 naturally aspirated 1.6 202KM/185Nm.
The most powerful D Series in Poland.
I built this car from May 2011. Check the movie: youtube.com/watch?v=IDmLaJGUtsU
Description:
ENGINE: D16Z6
y8 head gasket metal
oem honda pan gasket
shaft seals (both)
Aisin water pump, gates Kevlar belt, tensioner Koyo
oem thermostat
tp rings
Taiho bearings
honda oem oil filter
XADO oil 5w50
PM7 pistons polished with cranks of PM7 (D16Z5)
HEAD:
Comp Cams cam 59500 Stage 3
Crower springs
adjustable wheel
porting intake and exhaust
valves on the 3 angles
set oem honda valve sealants
planning
machined combustion chamber
CR 12.5
INTAKE SYSTEM:
cai Simota + h23 throttle @ 62mm and 62mm intake manifold - D16Z6 flange,
can b16a1, welded, polished channels, Heat seal on the intake and throttle h23
EXHAUST SYSTEM:
the exhaust manifold copy bisimoto 4-1, output 2.5 inches,
all wrapped in a bandage, 2.5-inch diameter exhaust, the final muffer M-TECH,
all stainless steel
ELECTRONICS:
coil, dome, MSD ignition cables, tuning Niuton, Varta battery back
DRIVETRAIN:
light flywheel, cluth ACT stage 3 up to 400Nm,
short box - 4.43 and a short five, dif. from del sol
SUSPENSION: AP,
polyurethanes, front upper strut, x-bar,
rear lower adjustable control arms front, Innovative traction bar
BRAKE SYSTEM:
front 282mm ECB with EP3 Type-R clamp, steel braid, servo and pump 1 inch
BODY-KIT:
laminates - mask, hatch, fenders, mirrors SPOON,
roof welded, the car after the full body workshops in 2013,
the new thresholds, fenders, all patched and protected
AGENT:
2 seats Mirco S3 + 4pts belts, MOMO 35cm steering wheel,
60mm gauge - oil pressure and oil temperature, knob Mugen,
short shifter buddy club, clocks EE8
CAR-AUDIO: pioneer
WHEELS: Advan wheels 15 "+ 195/50R15 Toyo R1R, 185/55R15 slicks Profile
POWER: D16Z6 IN 202.4KM / 185.0Nm
The car is to watch in Poland, Warsaw, Gocław. To take even today, in the car sunk 40k so the price a bargain!
PRICE: 4000 €
Contact: +48 515 802 972, rogalike@gmail.com
10884527_839632476076255_962391079_n.jpg, 62.92 kB
10888050_839632522742917_1304249545_n.jpg, 38.65 kB
10872697_839632472742922_1592462111_n.jpg, 33.31 kB
10893701_839632486076254_1484137133_n.jpg, 49.17 kB
10877972_839632519409584_997806337_n.jpg, 49.81 kB
10844675_839632512742918_2111329092_o.jpg, 148.78 kB
10876909_839632529409583_260659908_o.jpg, 159.78 kB
crx.jpg, 47.92 kB
Příspěvky: 322 1996 Civic
PříspěvekZaslal: 29.12.2014 , 22:09   Citovat
seskládané s využitím sériových dílů vyšších objemů pomocí "Lego principu" a nejsou tam drahé zbytečnosti.
Poláci a Maďaři umí, to je jiná scéna OK
Jen škoda, že nenabrousili origo DOHC, více dělané na otáčky. Na D16Z6 je ve světě dílů plná wc oproti dvojvačce, ale ty vahadla v hlavě.. DOHC na pořádných vačkách by bylo s Bisimoto "vánočka-type" svodama bomba Úsměv Můj dávný sen Úsměv
Příspěvky: 1842 1992 Civic
PříspěvekZaslal: 6.1.2015 , 0:01   Citovat
pěkný spec list, tomuhle se dá říct tuning, kolega si s tím zřejmě dost vyhrál, hezký prodej je to dobrý
PříspěvekZaslal: 12.1.2015 , 14:06   Citovat
Nikdo nechce raketu na kolech?
PříspěvekZaslal: 2.2.2015 , 12:22   Citovat
Sleva na 4000 €
PříspěvekZaslal: 3.2.2015 , 11:36   Citovat
Kdybych věděl , že někdo v okolí staví velice podobný engine set tak bych ten svůj asi nedělal. za ty peníze je to zadara a ještě bez práce.takhle v tom mám peněz hromady a práce jak na kostele. I když ten pocit když si to člověk poskládá sám.. HaHaaa
[ Čas: 0.0967s ][ Dotazy: 51 (0.0147s) ][ GZIP on - Debug on ]
