P: Yonaka Keramická spojková sada D15 D16 D14
boda_ul je teď offline  boda_ul
PříspěvekZaslal: 15.9.2015 , 21:50   Citovat
pojková sada jetá 2000km
Keramická sada (keramika) s pružinkama dimenzovaná až na 400hp
Yonaka 6-Puck Sprung Hub Performance Ceramic Clutch Set
Stage 3 Clutch kit
- Strongest clutch recommended for street car applications
- Rated to 300ft/lbs torque (approximately 400hp in D series applications)
- Copper Ceramic 6 puck Sprung Friction Disc
- Heavy duty 1800 lb Pressure Plate provides approximately 45% more clamping force than OEM.
- New Release Bearing is included
Please Note:
Heavier than stock pedal feel and some chatter at low RPM are to be expected with all extreme performance clutches. A 300-500 mile break-in period is recommended on all performance clutches.
Will fit the following models:
1990-1991 Honda Civic/CRX (1.5 D15, 1.6 D16)
1992-2000 Honda Civic (1.5 D15, 1.6 D16)
1993-1995 Honda Del Sol (1.5 D15, 1.6 D16)
2001-2005 Honda Civic (1.7 D17)
Kit includes:
Heavy Duty Performance Pressure Plate
Throwout bearing (Release bearing)
(Note: Throwout bearing does not fit early gen 90-91 - only 92+)
YMPCK002-2.jpg, 57.21 kB
Obraz0002.jpg, 377.77 kB
Obraz0003.jpg, 366.41 kB
[ Čas: 0.0458s ][ Dotazy: 31 (0.0046s) ][ GZIP on - Debug on ]
