H22A8
scorpione je teď offline  scorpione
PříspěvekZaslal: 22.6.2009 , 12:40   Citovat
ahojte lidi dokazal by mi nekdo rict podrobnejsi informac o tomhle motoru? co to je za typ do jakeho typu 5g preludy se daval a tak predem dik za info.
Příspěvky: 89 H+ body: 0 1997 Prelude VTEC
maryo je teď offline  maryo
PříspěvekZaslal: 22.6.2009 , 12:49   Citovat
H22A8
* This motor was only released within the 2000-2001 European versions of the Prelude and can be designated with the "red tops" and 200 horsepower (150 kW)
kandik je teď offline  kandik
PříspěvekZaslal: 22.6.2009 , 13:32   Citovat
tak tak
don't think that the differences between the H22A5 & H22A8 engine have been fully documented for the public, but after research I have found the differences are with the:
* Air intake ducting / filter housing,
* Camshafts with increased lift,
* Catalytic converter is a larger size (5cm longer),
* Different pistons giving a higher compression ratio,
* Enlarged throttle body from 60 to 62 mm,
* Exhaust manifold / down pipe,
* Exhaust piping has an increased bore of 57 mm instead 51 mm,
* Flexible pipe before the catalytic converter is shorter,
* Optimised ignition and injection timing,
* Valve seats readjusted from 60 to 45 degrees,
* Last but not least, the valve cover is red instead of black.
H22A8
[ Čas: 0.0526s ][ Dotazy: 37 (0.0053s) ][ GZIP on - Debug on ]
